Ferrari 250 GTO 1962 MFH 1:12 fulldetail-kit
GTO62
MessagePosté le: Lun Fév 15, 2016 11:44 pm    Sujet du message: Ferrari 250 GTO 1962 MFH 1:12 fulldetail-kit Répondre en citant
This model kit was already for almost a year in my house, but after seeing the model build by Fred Suber on Retromobil in Paris, I wanted to start to build my own.
I know, the kit is not easy, but I am going to try to do my best.
Lets start and first present the kit:
I am not going to build a race-version, I think, it's going to be a "stradale".
What's in the box?
A lot of white metal parts:
Some resin parts:
Divers small material:
PE-parts and tires:
Decals, rvs material for spokes and very important a guide for modelling:
Before we start, we had to split all the white metal parts, because MFH has put them in 10 bags, but all mixed up.
I spread out everything on the table and start to search!
For every picture in the guide, I made one bag with parts.
It took me three evenings to get this done and at the end, I had 32 bags.
More then a year ago, I already bought a machine for cleaning and polishing all those small metal parts.
It should cost to much time to do this all by hand.
Officially this machine is for polishing jewellery, but a lot of model builders are using this.
How the machine works?
In the machine there are 4 big magnets, which are turn around by an electro-motor.
You can choose for different speed, a timer and turning left or right.
On the machine is plastic bowl with very small steel pins.
When turning around, the pins are hitting the metal parts.
On this way, the metal parts will be cleaned and polished.
In the bowl there's a some water and a few drops of fluid for a dishwasher.
Because this is the first time I work with this machine, I had to try out how this works.
Searching for speed and time, it's important, because white metal is very soft.
When the machine is turning to long, you can loose some detail on your parts.
I start slowly and short of time, but now, I think, I've found the right turn.
For example, I did half of the first bag and I must say, it's looks good.
So, we can start and I am looking forward to this beautiful kit!
Depassage
MessagePosté le: Mar Fév 16, 2016 11:07 am    Sujet du message: Répondre en citant
well...here we go ! amazing project. I'm on the first place to follow you and your work. How many estimated time for the achievement ?
GTO62
MessagePosté le: Ven Fév 19, 2016 11:50 am    Sujet du message: Répondre en citant
Now all the parts are polished we can start to build.
Cut 12 pieces of brass-wire to put all these parts together.
My technical English is not so very well, but pictures will tell the story.
Now we have to pay attention to use the right parts (A,B,C or D) to make everything turning on the right way.
This all is not so difficult to do and easy to follow in the building guide!
It's a shame to build everything in, because at the end we have to close the whole engine.
When you do everything right, it must be possible to turn the axle around and see everything moving.
I did my best on it, but I came to one quarter of a turn and then it stuck.
But after all, I don't mind, when the engine is closed, you will see nothing anymore of this all.
MessagePosté le: Ven Fév 19, 2016 12:03 pm    Sujet du message: Répondre en citant
MessagePosté le: Ven Fév 19, 2016 10:11 pm    Sujet du message: Répondre en citant
Wahoo ! I'm in love with this kits, and I'm dreaming to build a V12 like this one !
Well done, waiting... Wink
GTO62
MessagePosté le: Sam Fév 20, 2016 9:45 am    Sujet du message: Répondre en citant
Thank you all guys. Smile
We start at the head of the engine and again a lot of small parts to polish.
I had to drill 156 holes in different sizes and make 48 small pins to keep everything together.
You must be a masochist to build this kind of modelkits! Shocked Cool Laughing
MessagePosté le: Sam Fév 20, 2016 10:09 am    Sujet du message: Répondre en citant
GTO62
MessagePosté le: Sam Fév 20, 2016 8:12 pm    Sujet du message: Répondre en citant
defre
MessagePosté le: Sam Fév 20, 2016 10:52 pm    Sujet du message: Répondre en citant
Shocked
suis scotché !!!! quel kit de ouf
GTO62
MessagePosté le: Sam Fév 27, 2016 6:56 pm    Sujet du message: Répondre en citant
It's time to close the engine, it's a pitty! Sad
And again we had to drill a lot of small holes, even to 0,40 mm.
It's not easy for my old eyes. Wink
Finally there's coming some colour on the engine.
In meanwhile we weathered the engine a little to get some more detail on the different parts.
Smile
MessagePosté le: Sam Fév 27, 2016 7:11 pm    Sujet du message: Répondre en citant
GTO62
MessagePosté le: Sam Fév 27, 2016 8:35 pm    Sujet du message: Répondre en citant
Thanks. Very Happy
It is a pleasure to build on this kit, until now everything is fitting so well.
Why don't you build your own paintshop?
It's easy and not expensive, you only need some space for it. Wink
MessagePosté le: Sam Fév 27, 2016 8:39 pm    Sujet du message: Répondre en citant
bass drum
MessagePosté le: Dim Fév 28, 2016 10:27 am    Sujet du message: Répondre en citant
Shocked this is just amazing ! What a kit !
MessagePosté le: Dim Fév 28, 2016 12:32 pm    Sujet du message: Répondre en citant
very impressiv job john . what do you use to the weathered ? it's wonderfull . Wink
GTO62
MessagePosté le: Dim Fév 28, 2016 2:04 pm    Sujet du message: Répondre en citant
Thank you guys! Very Happy
@Modena06: I use Weathering Wash from Models.co.uk.
It's easy to work with, it's on water base.
You see, I have different colours and you can use it for a lot of purposes.
And if you want, you can spray all kind of clear paint over it.
MessagePosté le: Lun Fév 29, 2016 6:50 pm    Sujet du message: Répondre en citant
Really impressive, congratulations, and keep the pics and comments coming Wink
lemonnier
MessagePosté le: Mar Mar 01, 2016 6:01 pm    Sujet du message: Répondre en citant
Frederic Suber m 'a envoyé des photos d 'un modèle monté . C 'est tentant ....malgré le prix
qui est justifié.
lemonnier
MessagePosté le: Mer Mar 02, 2016 1:00 pm    Sujet du message: Ferrari GTO 1/12 Répondre en citant
http://suberfactory.com/dossier-59-ferrari-250gto-lm1963-24-1-12.html
Photos qui m'ont été envoyées par Frederic Suber .
GTO62
MessagePosté le: Sam Mar 05, 2016 9:07 am    Sujet du message: Répondre en citant
Small update, still drilling small holes.
Only a few things to do and then is the engine finished.
Then we can start at the chassis! Smile
